Chlorine question
SteveK52
124
Taylors South Carolina
We will be leaving for a month or two next week and have placed a solar cover on our pool and reduced pump run time from 12 hours to 8 hours a day. I'm assuming with the cover that the chlorine level will stay the same without the SWG running. Am I correct, and any suggestions on other things to do before leaving? I have a backup generator and the freeze mode is working properly. Thanks in advance.
Steve
YippeeSkippy
14,453
Evans, Georgia
I would set the pump timer to run only at night. This is helpful on nights that will go below freezing. Eight hours is more than you need, IMO. The SWG probably won't be working (if it even still is?) in such cold water. Will anyone be checking on the pool in that time?
Maddie :flower:
SteveK52
124
Maddie,
Thanks for taking the time to reply.
The SWG still works on some days, however, I plan on turning it off if there will be no loss of chlorine with the solar cover is on. No one will be checking on the pool as there is no one in the neighborhood that I would trust to monitor it.
Shirker
561
Athens, GA - USA
Unless the cover is opaque you will likely still lose some chlorine, but what is your water temp? If you are 60ish or below, you should not have to worry about keeping chlorine up (assuming no one is swimming).
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,293
One or two months is a long time to leave a pool unattended. The chlorine WILL go down. If you have determined to leave it alone for that long, bring the FC up to SLAM value and it will probably be fine. Let us know how it turns out.
