Chlorine Loss
hawkmoon7
52
Florida
Moved from HERE
No, not yet. Excessive FC loss could be any of the following:
- Low CYA; your CYA, if tested accurately, if not low. I would not add anymore right now.
- Algae; even if you passed the OCLT, something is eating chlorine
- Old reagents causing testing error
- Human error in testing; inconstancy in water sample location or drops
- Old chlorine that is not providing a reliable FC goal
It might be good to do another OCLT. Before that, be sure to inspect all areas of the pool very carefully since we know algae can hide in all kinds of places (Behind lights with a niche, under a drain cover, etc) or anything else submerged in the water.
What do you mean by hiding behind the lights? I'm having a similar problem. I have Pentair Intellibrites and they say they aren't watertight, rather, the water is supposed to fill up the conduit under the ground. Can that be lurking with algae that is affecting my chlorine?
Texas Splash
32,954
Fiberglass
CircuPool RJ-45 Plus
The larger lights often have a hollow niche space behind them. The area gets stale and algae can begin to grow back there. That doesn't apply to pools with the smaller 3" LED lights that have no niche.
hawkmoon7
52
Florida
Hmm... I do have the smaller lights, but there is a niche they go into, and I don't see anything that would seal it. I think there is water in the electrical conduit. I can't imagine how to clean that out.
Thank you.
hawkmoon7
52
Florida
One of these was replaced after it was filled. They just gave it a half turn and pulled it out. Water filled the niche and electrical conduit (They are all filled with water since there isn't any kind of seal on them. I have seven). The conduit runs about 100 feet and then it's raised above the water line where it connects to the transformer.
mknauss
43,630
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Those are nicheless lights. The conduit fills with water. That is not a concern. No light gets into the conduit so algae cannot grow.
