Chlorine Level Still High from Pool Close
gwpruitt
4
0
Indiana
#1
I have a Pool Company close the pool in the fall.
Today I opened it up - smooth sailing.
Tested water - and chlorine is still through the roof from when the pool company closed.
Is that normal?
Other readings are as follows:
FCL-High maxed kit out
TCL - High maxed kit out
pH 7.7
Alk 62
CH 260
Thanks for any feedback!
jblizzle
41,193
4
#2
:wave: Welcome to TFP!!!
Perhaps not normal, but not necessarily a bad thing. Ideally you want there to still be FC in the water.
Well, what does "high" mean? Sounds like you need to get a better FAS-DPD chlorine test kit ;)
Also, there is no way to know what FC is "too high" without knowing the stabilizer (CYA) level. They are related according to the [FC/CYA][/FC/CYA]
jblizzle
41,193
4
#4
Well, we do not recommend that colorQ ... and what you are seeing is one of the major reasons. It does not read the FC high enough.
Also, results tend to be sporadic and impossible to know when it is "lying" to you.
These are the only Recommended Test Kits
Damage is dependant on what the actual FC level is and what the actual CYA level is.
jblizzle
41,193
4
#6
I would steer you to the TF-100 as the better value for the test that you will actually be needing to do more often.
OTPirate
Admin
In The Industry
Oct 3, 2013
1,320
0
46
Creedmoor, NC
#9
Hey! Sorry about that! I'll send it out tomorrow. You can still test your chlorine with R-0871 and R-0870-you won't be able to test for combined chloramines-which you should be ok for a couple days. I'm very sorry about that! I'll PM you to verify your info!
