Do not test pH right after adding liquid chlorine. The whole process of chlorinating your pool water with liquid chlorine is pH neutral. It is slightly alkaline when just added.
A good question to ask given my level of experience! But I have been testing 12to 24 hours later to see what next dose needs to be.
My TA is on the high side at 150 or so.
TA Is my problem I think then. There was a good bit of splashing in the pool today. I best either use the dry acid I have or bite the bullet and get some hydrochloric. How bad is dry acid?
The pool is inside a Perspex frame so no rain. Only dilution has been the recent large exchange I did to reduce cya from 300 to 60. I’ve Not added anything since then other than a handful Of cal Hypo mugs but now just liquid chlorine.
Otherwise draining Is just backwashing. Which having only just installed a working pressure guage I’m not sure how frequently I will do.
so after a day of no swimming my ph seems to have come back down to It’s usual level of around 7.6 from 7.9. Is that realistic or have I got some duff readings going on?
