The tab feeder is to be replaced at some point soon with a SWG, or, should I leave, and if so, where put SWG?
But, also there is the issue with the valve to right and below tab feeder. I had issue with the tab feeder not producing a thing on slow flow, and it was felt that that the skimmer return should have been on outlet side. Either way, long story of not getting brand name of skimmer from pluming contractor, possible missing nozzle in skimmer, and whether or not valve should be moved, the PB just sent someone out to put this low flow model feeder on and it works if I want to use it.
The skimmer nozzle issues, though minor, remain to be addressed. Is there a generic I can buy with same thread size?
Currently, I have just left the skimmer return closed and my skimmer works fine as it is.
I guess my question is if the SWG is to go where the feeder is now, the skimmer nozzle and valve need brought up to snuff??? Don't really need the venturi effect??? I don't know. Ideas?
