Chemicals Required at Closing
Wirides
10
NE Wisconsin
Moved from HERE
That begs the question, exactly what chemicals at what level are reccomended at closing? This is our first winter as our pool was just installed last month.
Texas Splash
Welcome to TFP! :wave: For your question, you'll want to review either of the links below depending on your pool type. They also address the chemical aspect. But basically after standard chemical balancing and final cleaning, increase the FC to "SLAM" level (see our FC/CYA Chart), let it fall a bit before adding algaecide (if used). Close when the water temp is below 60. Don't forget to review our ABCs of Pool Water Chemistry for more info, and let us know if you have any questions along the way.
