My chlorine levels have been high for over a week, and I haven't added chlorine in over a week and a half, and ph is low. I use the Taylor K2006 test kit. I was getting,
free chlorine 5ppm
Combined= 5ppm
Ph= 6.8
Cya= well above 100. My pool is clear. So I took a sample to our local pool company, and had them test. I'm attaching their readings. I'm more confused now, then I was. Any help would be appreciated! Do I need to drain water, and refill? I have used tri-chlor granules for the last 4 years, with no problems. However, the last 2 openings my pool has remained pretty clean all winter, so I haven't had to vacuum on waste. I'm wondering, if that is why my cya is so high this year.
16'x32' inground, vinyl liner, sand filter
24, 000gal
free chlorine 5ppm
Combined= 5ppm
Ph= 6.8
24, 000gal
