I’m redoing some plumbing for my equipment.
I’m not sure about which check valves to use.
I’m adding a check valve in front of each filter for my pool/spa.
Can I use the regular type of in line check valves sold in hardware stores?
Or should I use the jandy type of valve with a flapper?
Or something else maybe I am not aware of?
I’m concerned about possible pressure loss due to the design of the check valve. Not sure if it’s a valid concern or not.
