Check Valve Failed - Which One?
Texanscot
5
Texas
My main circulation pump failed a few days ago and while waiting for repair I noted that my hot tub drained. From various sites on the web I understand that this is normally indicative of a failed check valve which is allowing water from the hot tub to drain back to the pool.
My question is regarding how I might identify the particular valve that has failed. I've attached a picture of my pool return configuration. Essentially what I see is that water flows from the heater through a check valve and into a diverter valve that has outputs to both the pool and spa. There is, on the spa return line, a connection with a second check valve that goes into the ground. I can't for the life of me figure what this is for but I'm thinking that this check valve may be the one that has failed.
However it appears that there is a separate jet pump that provides water to the water feature (waterfall over side of spa) that also has a check valve on the discharge side (see the attached pic). I don't know where the suction for this pump is but assuming that it comes from the pool failure of this check valve could also result in drainage from the hot tub to the pool.
Is there a way to figure out which of these two check valves is the one that has failed?
Also, when replacing the check valve do I need to close any valves to isolate the system or is it sufficient to simply have the pump turned off?
ajw22
18,150
Northern NJ
The water feature pump should suck water in from the spa and return it to the spa. It would not drain water back from the pool if its intake is in the spa.
That leaves you with the check valve on the spa return line. If it drains water then you need to plug the return in the spa before opening it up.
Texanscot
5
Texas
The water feature pump should suck water in from the spa and eturn it to the spa. It would not drain water back from the pool if its intake is in the spa.
Thanks for your response. Can you advise how I would plug the return in the spa in order to be able to replace the valve.
mknauss
29,787
Laughlin, NV
I believe you can pump the water from the spa into the pool. Until you get to your spa drains. Should be enough to keep the check valve area dry.
Texanscot
5
Texas
How would I go about this? Is it possible to do using the pool plumbing or do you mean using some kind of external pump to transfer the spa water to the pool?
Thanks.
mknauss
29,787
Laughlin, NV
If you put your actuated valve to Spa suction and the return to Pool, it will pump out of the spa and into the pool.
Your actuated valves have a toggle switch on them. They are on-off-on. Move them to get the valves set for the above. Be sure to move them back once you are done. It will fill the spa when you do.
mknauss
29,787
Laughlin, NV
If you have automation (a Signature would be of great help) it may have a Drain function. That will do the same thing.
Texanscot
5
Texas
Apologies - I'll add a signature to my profile.
I do have automation via Aqualink RS6 however I don't recall that there is a function (or button) available to drain the spa.
ajw22
18,150
Northern NJ
Look on the outdoor panel. Spa Drain button is on the top left. Put the panel in Service Mode. Press Pump. Press Spa Drain. Turn off pump when spa at the required level. Leave panel in Service mode while you do repairs.
Texanscot
5
Texas
Thanks so much - really appreciate the help that you have both been providing.
