Changing Value locations on Intex xtr pool
MS82
1
UK
Hi all, We have sunk an Intex XTR pool into the ground and have recently upgraded the pump, filter, and heater so that we don’t have to access them from in the hole under the ground, under the decking. On doing so we have realised that the best place for our equipment is on the opposite side of the pool but we don’t want to move the pool because it’s a lot of hassle as it’s in decking. I am hoping that I can just leave the inlet and outlet valves as they are in the turnoff position, and cut new holes the other side of the Liner and add new valves. Has anyone had experience of this and is it a good idea or a really bad idea. Thanks for your help, Michelle
Teald024
Hello and Welcome to TFP!
Many users have put a typical Hayward return jet on an Intex type pool. It’s not difficult and not a bad idea. If I was going through the trouble of doing this, I’d put a skimmer in for the intake instead of double suction ports. Especially since you’ve upgraded the pump.
I don’t really like the idea of leaving the old ports and valves. The only downsides I can think of would be a place for algae to grow or potential leaking. Perhaps you can get a patch large enough and cover each port from the inside to seal them off. Then leave the valve open until it dries out inside and then close the valve for insurance.
kellyfair
3,696
Tampa, FL
Intex Krystal Clear
Or you could plug them. That’s what I did with my unused suction (after installing skimmer). Let me see if I can get a good photo.
kellyfair
3,696
Tampa, FL
Intex Krystal Clear
Mine is a Hayward 1.5“ drain plug which appears to be unavailable now, but maybe you could find similar. It’s a perfect seal, not one drip in years.
