Hi all,
Sand has started entering my pool so I assume the that there is a problem with my filter so I need to empty the sand to see if it is repairable. The filter is an Astralpool 800mm diameter filter with a side-mounted multiport valve. I have removed the top cover which exposes the diffuser but I cant seem to remove this. Are the diffusers normally screwed on or should it pull off? Any help would be much appreciated. Thanks.
