Changing filter from Sand to DE
Matt_PEBKAC_Oh
152
Bluffton, Ohio
Fiberglass
CircuPool RJ-30 Plus
Will there be pressure loss returning to the pool if changing from Sand to DE filter? I HP single stage pump.
skimmerswimmer
487
Long Island, NY
I used to have a sand filter and a 1HP pump and switched to a Pentair Quad 60 DE filter. I didn't notice any pressure loss. If you're concerned, you can always go with a larger filter. I was considering the Quad 100, but I wanted to hide my filter behind a 4 ft fence and the height of the quad 100 was too high.
Reactions: Matt_PEBKAC_Oh
skimmerswimmer
487
Long Island, NY
I have since switched from a 1HP pump to a 3HP variable speed pump...it is much quieter and saves a lot of electricity. Might be something to consider if your 1HP pump ever gives you any trouble.
Matt_PEBKAC_Oh
152
Bluffton, Ohio
Fiberglass
Thanks. The pump is 2019 Pureline PL2601 Inyo special, hayward type strainer box. The first one at the begining of 2019 had a bad shaft leak after a few months. Got a new unit sent but didn't power on until 2020. It only got a few months of abuse until the baqua white mold Crud shut me down early. Hate to toss a barely new unit but we shall see. I only have a 13,700 pool so I am hoping the 20,000 gal rating on the Hayward 65 unit does the trick. I'm on 1 1/2" piping all around.
YippeeSkippy
17,628
Evans, Georgia
After you get rid of the Bacquagoo, you could keep your sand filter (with new sand) and add a smidgeon of pool DE to the sand to help capture the smallest of debris. I do this to my sand filter. You will lose that DE with backwashing but you just repeat the administration of it and you're back in business.
Maddie :flower:
