Changing date and time on the thread
mariane
883
Southeast Michigan
At the left upper corner there is a time and date that is not the same as when I am actually posting.
It is Thursday 8:19 pm as I write this but not the same as the time and date in the corner.
Is there a way to sync these?
Thank you.
JamesW
18,366
What time are you seeing on your posts?
It initially says how many minutes ago you posted, then it changes to the date and time and it will later just show the date.
Do you have the right time zone set in your settings?
JamesW
18,366
Note that traveling near the speed of light or being close to a black hole will affect the rate of time passage vs. a different inertial frame of reference.
Adjust using the Lorentz correction factor.
  • Haha
Reactions: mariane
mariane
883
Southeast Michigan
Yep, seeing that it's showing minutes. When it changes to date and time is when it's really off. :unsure:
I was thinking the same thing but I can't find where to change the time zone settings. :scratch:
mariane
883
Southeast Michigan
Ah found I'm in Dublin, Edinburgh, Lisbon, London
Phew! It's not the Delta Quadrant.
Thanks @JamesW. I'll change it.
Just wondering. Why in the world would you leave August 2027 to come to May 2020 during "The Covid"? Even Spock and James T. Kirk refused to stay in 2020.
Reactions: JamesW
