“CELL NOT HOT”
Jerry M
8
Bensalem Pa
CircuPool RJ-45
I don’t know what this read out means on my RJ-45 SWG and what I have to do to correct it. Also it is not properly chlorinating the pool and the water turns green. Thank you.
RJ-45
In The Industry
Jun 6, 2021
147
Charlotte, NC
It means the temp sensor inside the cell has failed, the maker of the hardware come up with a way to read temp from flow switch instead.
Just call the company that sold you the unit, they will walk you through this procedure.
Jerry M
8
Bensalem Pa
CircuPool RJ-45
I called the manufacturer twice each time I was put on hold for 15 min first time and 8 min second time and after each hold period a voice came on and said they are busy call back in 30 min. Waste of time also sent an email received no reply. Thanks for your suggestion but they have no service
Jerry M
8
Bensalem Pa
CircuPool RJ-45
Thank you I will try again
RJ-45
In The Industry
Jun 6, 2021
147
Charlotte, NC
All pool company are busy now. If you still have trouble getting them to help you by this weekend, I have the part you need. First move the jumper over, it should go to the default temp. So you can use the machine to generate. But your salinity reading is not temp compensated, so it will be off a bit until you can put in the special flow switch.
Jerry M
8
Bensalem Pa
CircuPool RJ-45
What is the jumper that I would have to move over?
Rancho Cost-a-Lotta
3,704
Rancho Cucamonga, CA
CircuPool RJ-45
I got a response within a few hours after sending in an online support request. Here's the link if you want to give it a try.
