CC level of 8.19ppm - should I really add 20 lbs of cal hypo!?
JamesW
25,848
I have cal hypo and dichlor
You can use either one, but "DO NOT" mix them together as they will explode if you do.
You can alternate which one you use, but do not add both at the same time.
Make sure that you are brushing well.
mknauss
41,849
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
ok thanks. I can't get any liquid Cl right now (all sold out) - should I use cal hypo or dichol?
I checked the Ocean State Job Lot 12 miles from the city you show as your location. Liquid Shock is in stock.
Reactions: JamesW
JamesW
25,848
If you use a bucket to mix the chemicals, make sure that the bucket is perfectly clean before adding any chemical.
Even residue from a previous mix can have bad reactions.
BassPlayingDude
439
Media, PA
I used Natural Chemistry's Metal Free. I can't get my hands on any liquid Cl right now. It's sold out in all of the pool stores in my area. I have cal hypo and dichlor
Leslie's in the shopping center @ sproul rd and state rd in Springfield has 12.5% liquid shock in 4 packs for a reasonable price (like $22-$24)
BassPlayingDude
439
Media, PA
Ollies @ granite run has 10% jugs for $3.98 (Limit 10) Id call first though, they had like 12 cases left on Sunday.
Reactions: JamesW
BassPlayingDude
439
Media, PA
Ace Hardware usually has the 12.5% jugs for $6.. so does the Walmart on state right @ the 476 exit in Marple Crossroads SS
