Cartridge keeps cracking
emerisrose13
12
San Antonio
Hello all, we bought our house in 2019 and it came with a pool. If I would’ve known it would be this much of a headache and expensive I wouldn’t have bought the house! I’m very discouraged and don’t know what to do anymore. I did have a family friend that is in the pool business but I feel like we’re in this situation because of him..
The pump was bought and replaced when we bought the house in 2019. The filter was replaced in 2021 after the snow and freeze in Feb 2021. Since then, the cartridge that came with the filter in the original box cracked. Since then, we haven’t had a clue what to do but keep shocking the pool. We finally went to local pool store and bought new cartridge. 1-2 days we were so happy because the water was clear!! But then the cartridge cracked 🙁.. went back to the pool store and was able to get the cartridge replaced. Come home and installed new cartridge after running pool without it to check psi.. psi was right below 10. We put the cartridge in and let it run for a few hours. Went back to check and it was cracked!!!!!!! Can someone help please? 😢
ajw22
41,375
Northern NJ
Pentair Intellichlor IC-60
Cut the pipes connecting your filter and turn the filter 180 degrees.
And while doing the PVC work on the filter remove the DWV elbows that were used on the return side and use Schedule 40 pressure rated 90s.
emerisrose13
12
San Antonio
These are all the pipings and their labels that are on the system. I notice that not only is the chlorinator in the wrong spot but it’s backwards as well 🤦🏽‍♀️
ajw22
41,375
Northern NJ
Please read PVC Repair - Further Reading
You have a mix of good schedule 40 fittings and bad DWV plumbing fittings. The LASCO fittings are good.
Schedule 40 fitting have deeper hubs for the pipe to go into then DWV fittings. You can identify the DEV by the shallow hubs.
In the pic below I circled in red the DWV joints that were used between the filter and return into the ground. The blue circles are fittings that look like Sche 40 from the pic.
Whoever did the plumbing work on the pool did not know what they were doing at various levels.
emerisrose13
12
San Antonio
So the red circles, those joints need to be all the schedule 40 joints instead?
generessler
419
Chapel Hill, North Carolina
Jandy Aquapure 1400
Yikes. An inventory:
  • Filter installed backward
  • Chlorinator in the wrong place
  • Wrong pipe (DVW)
  • Pump intake should ideally have a 10" run of straight pipe after the last joint or valve.
I added the last. It makes life easier for the pump, so it lasts longer. There's no shortage of space, and you're re-plumbing anyway so might as well.
If you can find out who did all that, never let them touch the pool again.
Reactions: emerisrose13
