So recently my Hayward 4 cartridge filter has been at around 35 PSI when running. The manifold did have a crack and I changed that last week, which I am assuming cracked due to the high pressure. I have cleaned the cartridges (about 2.5 years old) multiple times in the last month since I thought that might be the problem, but I ran the filter without the cartridges and the pressure was still pretty high between 25-30 PSI. I believe it used to sit at around 10-15 PSI, not entirely sure since I don't live there currently and it is a rental home. I tried checking the in and out pipes when changing the manifold to see if there is anything stuck in there but did not find anything blocking the path. We did recently change the pump since that went out about 2 months ago, and I believe the high pressure started around then, but I am not entirely sure if it had anything to do with it.
Does anyone have any ideas of anything I could check to lower the pressure? I have attached pictures of my system. This is my last effort at fixing it myself, before I just call someone to take a look, so any help would be appreciated.
Pictures of system: Imgur: The most awesome images on the Internet
