cant seperate union
anthony21078
92
Long Island NY
Hayward VS pump was installed at the beginning of the summer with some new plumbing. Im trying to seperate this union but it wont budge. I dont know what it looks like on the inside (meaning if it is some type of slip fit connection or mearly pressed together with a o-ring) but I cant seperate it. Any suggestions?
Jimrahbe
18,825
Bedford, TX
Anthony,
I use a large pipe wrench when they get stuck...
Could use a strap wrench, but I don't own one..
That said... it appears you got it, looking at your pics..
setsailsoon
3,338
Stuart/FL
Antony,
If it's close coupled on both sides you may need to loosen the pump mounting so it can slide away. All that's there is a flat mating surface on both sides and one has a grove with an o-ring.
Chris
Reactions: anthony21078
Jimrahbe
18,825
Bedford, TX
Anthony.
As Chris points out, there should be nothing holding them together... Maybe a little dirt, but no glue or anything else.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,289
Can't tell, but it doesn't look like you have much room to break it free. Can you tap it with a rubber mallet just to break any seal that may have inadvertently formed?
anthony21078
92
Long Island NY
I'm away from the pump right now and haven't fully winterized it yet. Does the top pipe likely have some type of o-ring in there or are both services supposed to be smooth and just sit flush together?
I know I have to get that glue off so I'm guessing some light sanding would be the best option?
JamesW
20,410
The top part has an O-ring. I would probably scrape the surfaces smooth with a razor knife. Sanding can work as long as you can get the surfaces smooth enough. Maybe use several different sandpaper grits and work down to a super fine grit to polish the surface smooth.
