Hello,
I am a 1st time pool owner and been maintaining it for the past several months. It wasn’t much an issue at the beginning but it’s summertime in Houston and I cannot keep the chlorine levels up. There was an issue with the chlorinator before but that has since been changed out. My pool is less than a year old, gets full sun all day, and a lot of wind being on a corner lot. The builder/pool company hasn’t been able to provide an answer other than raising my CYA which led me to doing some research and finding this forum.
I’ve read some of the suggested links and a few threads over the past few days and decided to join. I went ahead and compeleted the overnight free chlorine test which resulted in .4ppm loss so it seems majority of the loss is during the day. I’m currently running my pump 12 hours per day at 2400 RPMs. After the loss I started the day at 3.2 ppm FC only to test it the next morning resulting in 1.6ppm FC. I’m currently using 3” trichlor (provided by builder) and have been adding bleach as a booster when needed. I saw that everyone recommends bleach instead of tabs. I’m sure i should switch but wanted to use the tabs and shock that was provided before buying other products.
My current levels this evening are:
FC - .6
CC - .6
pH -7.6
TA - 100
CH - 290
CYA - 40
I am currently shocking it to get the FC back up. The water has always been crystal clear and never an issue. The builder suggests our levels are ok at 1.0-1.5 FC since we have an ozone and UV system (wish I found your threads regarding these beforehand). Any suggestions are greatly appreciated. Looking forward to learning and sharing with others.
FC - .6
CC - .6
pH -7.6
TA - 100
CH - 290
CYA - 40
