After adding muriatic acid and bringing our TA and Alkalinity into balance, I set out to shock the pool. I have used 4 lbs of calcium hypochlorite for two out of the last three evenings and still can’t even get the chlorine to register, PLUS, now the ph is almost at 8.
I read that cal hypo raises ph and that high ph consumes chlorine. How can I keep chlorine in my pool using cal hypo if it raises ph and high ph consumes chlorine? Do I just need to resign myself to the fact that I will be adding tons of muriatic acid and spending a fortune on chemicals? On top of this the pool got cloudy the minute I started using cal hypo.
Cya is at 60
TA is at 100
calcium hardness is at 320 (had to raise it recently as our well water is so soft so this may be a bit too high?)
ph almost 8
chlorine at 0
Note: We have feeder with trichlor pucks that is set at 2.5. I just changed to cal hypo for shock rather than dichlor to avoid cya overload after learning the hard way.
Thanks for any help!
Cya is at 60
TA is at 100
ph almost 8
chlorine at 0
