Hi!
We recently moved into our new home with an above ground pool. We had an inground salt pool in our last home so I am familiar with pools but this one seems like so much more work! We discovered a hazy brown cloud floating in our pool. It was nothing we could net, and when we used our pool vac, it would just spread out. Took several water samples in to our local pool place. They said that it was an organic algae because of the slime it was producing in our filter. They had us add acid, then pool first aid, then drop down. All on separate occasions. I decided to take matters into our own hands and grab a TFP testing kit and download the Pool Math app on the recommendation of my sister.
3 days testing numbers (NOTE: there were 3 days between day 1 and day 2 testing)
Day 1 - FC 60 / PH 7.5 / TA 187 / CH 225 / CYA 150
Day 2 - FC 40 / PH 7.6 / TA 110 / CH 250 / CYA 110
Day 3 - FC 40 / PH 7.5 / TA 150 / CH 325 / CYA 100
Day 1 we tested the water, let the water settle for a few hours then I got in and vacuumed whatever brown stuff I could see floating before it all got stirred up from the jet being turned on. Then we left the pump on all night. Continued cleaning filter of debris and making sure the filter pressure didn't go over 10.
Day 2 we tested the water, continued running the pump. Continued cleaning filter of debris and making sure the filter pressure didn't go over 10. That night, we removed water from the pool down below the jet, turned off the pump, let the water settle and again vacuumed up as quick as we could anything we saw floating in the pool. Then we filled the pool enough to run the pump over night.
Day 3 we tested the water, pump still running, began adding the water back in. The filter is running at a constant 10 and is clean as a whistle. The pool water still cloudy but starting to see the bottom. Chemicals are still way off.
Any help would be appreciated! I want to get this pool back to where it needs to be so we can keep swimming before our FL winter HA
