Can’t get pool blue new filters needed?
dielseman
54
GA
Hi there,
Having some trouble getting my pool blue. I run the filter every day for 4-6 hours and maintain the chemicals. I’m using the Taylor kit and tested all my chemicals.
Living in Georgia, we have been receiving a lot of pollen. Does that attribute to this somewhat murky color?
Also, the PSIs are 20 for the filter. Was thinking a new filter might be needed.
Do I need to run the filter longer?
What do you think?
Jimrahbe
11,450
Bedford, TX
D-man,
You have been a member since 2017 so you should know the drill by now... :scratch:
Please post the following numbers
FC
CC
pH
TA
CH
CYA.
While it is possible that you have a filter issue, it is almost a sure bet you have an algae bloom..
Have you run an OCLT yet? Overnight Chlorine Loss Test
If not, that would be the very first step that I would do..
dielseman
54
GA
I probably need to do that as I have noticed about 2 ppms in chlorine lowered each time I test the following day. I just presumed that was due to the high amount of pollen. I will post these when I can. Did not have that with me at the time.
On a side note, do I need to run the filter longer and possibly buy a new filter? It is several years old and I have already cleaned it rigorously a few times. Best I can get it down to is 10-15, then it rises pretty quickly.
dielseman
54
GA
What kind of filter?
I have a Jandy pump. How often do the filters need to be replaced? The strings that wrap around the filter are pretty much ripped. I can get it cleaned well, but it only lasts a little while. I mentioned in my previous post that I can get it down to 10-15 psis, then it rises to 20 within a few filters.
Teald024
A 2ppm loss of FC each day is normal. But, you may be on the verge of an algae bloom. Although the filter may look a bit dirty, they are probably fine if you can’t then white again.
Pollen tends to float and can increase FC consumption, but it’s likely you have non-filter issues. More likely the start of algae due to low FC for your CYA.
Please post a full set of test results and the method of getting them.
dielseman
54
GA
Will post them once I can. To combat and algae bloom, would need to start the slam process, right?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
31,533
Start your SLAM as soon as you can. Bring the FC to around 24 ppm and KEEP IT THERE until your pool is clear. You must run the pump 24/7 during the SLAM and keep the filter cleaned as necessary.
dielseman
54
GA
Thanks! Do I need to drain waiter or raise ph before starting the slam? Or is the most important thing going to be adding liquid chlorine and running the filter? Also, just making sure that if I raise this to 24 PPM I should add all the bleach at one time? Approximately 225 ounces.
Teald024
Your pH is Ok for now. Only reason to drain would be the CYA. At 60ppm, it is higher than desired for the SLAM, but not undoable. Most important thing is to keep FC at SLAM level based on your CYA. Effectively, the only downside is the extra use of the testing reagents used while testing. It’s your call if you want to put up with the consequences of higher CYA. SLAM process will work either way.
Yes, dump in all the chlorine at once to reach 24ppm.
dielseman
54
GA
Thanks! Lastly, on here it is recommended to pour the chlorine slowly above a intake valve. I’ve seen some videos where they pour around the perimeter of the pool. What’s the best way?
Texas Splash
We recommend pouring slowly at those return jets coming back into the pool. That way the bleach is quickly taken away and dispersed. Some smaller pools with limited return jet force may still need a quick brushing to help get the chlorine moving around.
Thread starter Other Threads of Interest Forum Replies Date
X Above Ground Pools 0
P Testing and Balancing Your Water 4
Y Just Getting Started 53
