Can't get pH up, am I missing something?
toofast
987
North East Ohio
#1
I follow TFP religiously...but this year I am struggling to keep my pH up.
FC - 6
CC - 0
TA - 80
CYA - 60
pH - 7.2
I've followed the calculators and have added enough pH to go 7.8 three times over and it keeps dropping to low 7's
I use Borax 20 to boost.
Any idea or any thing I should provide to help out ?
Thanks in advance!
JamesW
12,837
#5
Does it go up and then back down or does it not go up at all?
Have you used trichlor tabs or granular?
Have you added cyanuric acid?
toofast
987
North East Ohio
#6
Ok, wow....all good questions.
1) Aeration...got it, but every other year I have had rock stable pH with the same TA, etc.....so what changed ?
2) TA Raise with Baking Soda...so yes, but last year and every other year TA of 80 gave me rock solid pH....so I am stumped.
3) Unsure of fill water, but in all reality I've NEVER added fill water in the last 4 years, it is always rain water.
5) YES - I did add Cyanuric acid about a month ago, but this is all problems that have risen since...I did for some insane reason over shoot CYA, wanted to target 50, but got to 60 - could there still be some crazy strong acid....weeks later ?
Also, I should add some Borax and then 30 min later test....that I have not done yet, so I will.
JamesW
12,837
#13
Are you sure that you have the right Borax?
How much are you adding and how long after adding do you test?
Is your solar cover new?
toofast
987
North East Ohio
#14
20 Mule Team Borax, gotta be the right stuff correct ?
So I gotta strange question, assume yes, but hey just in case.
If I get my speedstir going, and then I add some borax to the cell the pH should be off the chart correct ? Would that at least tell me if my solution is good ?
toofast
987
North East Ohio
#16
You say that your fill water is rain. Maybe there is more acid in your rain water this season?
Dang...I mean yes that is possible for sure. But if I test my pH, it is 7.1, I then add enough Borax to get to 7.6 say, yet it still reads 7.1 a day later with no rain.
I will get some more reagent and hopefully that is it....assuming there is a shelf life.
