Can’t get my pool light fixture out, please help
sloanhaus
6
Orlando FL
I am trying to replace my pool light fixture and having a really hard time. I disconnected the ground wire in the pool but for the life of me can’t figure out where it goes. I have a spa light and pool light and have disconnect both. Neither pvc tube has the ground wire in it. I have tried pulling the ground wire and the light wire with my golf cart and they snap before they move. Any help would be greatly appreciate.
ajw22
28,522
Northern NJ
Pentair Intellichlor IC-60
Did you disconnect the light power wires at the light junction box?
sloanhaus
6
Orlando FL
Yes. I disconnected all three wires. In the pool there is the 3 wires from the junction box and then a separate ground wire. I can’t find the ground wire other end. Someone said you have to pull out the ground wire before the light wires will come out.
1poolman1
In The Industry
Jul 14, 2014
114
Sacramento
A separate, 8ga, wire inside a light conduit is the bond wire. You can look up pool electrical bonding elsewhere. It should be connected to a bonding lug inside the light niche and then encapsulated with a special compound so as to not corrode off. It is then connected inside the light junction box to one of the bonding lugs there. You should not have to pull that wire if the builder did the job correctly by pulling and installing that wire first and then the light cord.
ajw22
28,522
Northern NJ
As was said above the bond wire is not your problem.
Pulling out the light wire can go very easy or very difficult. If the wire goes through a 90 degree elbow it can become difficult. Here are some prior threads discussing how to handle pulling a light wire. Lots of good tips in the threads about using lube, pulling from both directions, using a rope puller, and more....
