So I'm not sure why I didn't post about this a long time ago, because it is a frustration we deal with every year. But here goes...
I have an above ground pool with a typical cover. The water can pass through the cover. Every year when we go to remove the cover, the water below looks good. We can actually see the bottom when we take the cover off. However, as we pull the cover to the side of the pool, the water won't drain through the cover. So we pull and pull at the side of the pool...and the water collects in the cover and we can't pull it out. Eventually we give up and just pull the cover out, letting the water and junk that was on the top dump into the pool. Now we can't see the bottom. No good.
What am I doing wrong? Is this just an "it is what it is" situation? How do you all get your covers off your above ground pools without having this happen? Should I buy a different cover, like a rigid one like in-ground pools have? Any recommendations?
Thanks so much for the advice everyone.
