Can't find Century pump replacement O ring kit
Beluga_J
5
Houston
Hey All,
My pump seems to be leaking and I can't find a replacement Century O-ring kit. I'm considering replacing the entire pump as it's also running louder than it used to. I've cleaned out the impeller and wiped the existing O ring clean. Lubed everything up and tightened it all back down. Still seems to be a little noisy and leaking a bit. I'm wondering if anyone knows where to find Century O ring kit or compatible brand. Also, if the time comes to get a new pump any recommendations for cheap reliable easy to maintain pumps would be appreciated.
Thanks!
