That water does look like a SLAM is in order. Are those green patches algae, do they react to brushing, or are they metal stains?
Don't worry about TA now, you need to get chlorine in asap. You should never allow FC to drop below the min level in the FC/CYA chart.
I suggest to follow the SLAM process:
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.
www.troublefreepool.com
Keep the SWG off for now. Once your pool is clear, you can add more salt and start the SWG.
The K-2005-Salt is a great kit, but it doesn't have the FAS-DPD test, it only has DPD. That means you add DPD powder or drops which turns the water pink. The exact shade of pink correlates with the FC-level. That is not very precise and doesn't allow to test at higher FC-levels required during a SLAM.
Only the K-2006 has the FAS-DPD test. After adding the DPD, you add FAS drops until the sample turns from pink to clear. The number of drops gives you an exact measurement of the FC-level.
You can buy a separate FAS-DPD test as an add-on to your K-2005 kit. You will need that for your SLAM.
