Can you switch from chlorine during summer And install SWG?
Seewll
2
WINSTON-SALEM NC
What, if any issues would I encounter if I want to switch to salt water pool in July? Currently I have 30,000 gallon with liner. New liner installed in April 2020.
mknauss
31,283
Laughlin, NV
Welcome to the forum!
A SWCG generates your chlorine for you --
Tell us more about the pool. What pump do you have, any automation, etc. You have a large pool volume, so a SWCG will need to run at least 12 hours a day to make your chlorine. A single speed pump might be pretty expensive to run that long.
Will you install this your self?
I suggest you read ABC's of Pool Water Chemistry.
WaterTech1968
In The Industry
Sep 4, 2007
38
From point of view of chlorine, it will just start generating some Sodium Hypochlorite, should not affect much apart from you needing to watch it over next few weeks and adjust output accordingly. What may have some affect is increase in pH drift but it minor, and effect salt may or may not have on your equipment, depending on concentration. The SWCG installer should cover all of that during initial install process.
Seewll
2
WINSTON-SALEM NC
Thanks for reply. I installed a Hayward MAX Flo VS last year after we moved in. I have a Hayward swim clear cartridge filter and chlorine tablet dispenser. Was thinking about switching over to salt. I just purchased Taylor Complete test kit.
mguzzy
2,050
OV, CA
You won't be disappointed with a SWG. You can install them anytime. There are some slight differences in the pool chem levels. but that is it!
BTW.. welcome to the forum!
Beerfloater
121
North Carolina
Hey Guys Seewll is a very good friend of mine... I would like to welcome him to the forum like everyone else. I told him he would be warmly accepted here, and everyone here is eager to help. I have recently been offered to purchase a one year old SWG for half of what it sales for new. Another friend of mine has a fiberglass pool, and used it for a year. He loved the SWG, but he noticed little black spots on the bottom of his fiberglass pool, and someone convinced him it was some sort of reaction between the fiberglass and the salt.... I am not sure if that is his problem, or not but he has already switched back to using chlorine. His lost is my gain. Sorry for hijacking your thread Seewll, but if you decide to spend some of that stash your sitting on, and get a SWG I just may convert at the same time. **** we will figure it out together along with some help from the good people here at TFP.
Rossterman
485
Martinez, CA
The key is to get the proper sized model Which is why folks need pool info and what, if any automation. Undersizing a swg is the biggest mistake folks make. Since you have a VS pump, you could even run 24hrs a day economically but post the info so folks can make Reccomentations as to what make and model would be your best bet.
