We're midway through our pool build, and our pool builder included the Pentair Prowler 920 robot. But, I'd prefer not to leave it in the pool all day. So I imagine yanking it out emptying the bin, then manually dropping it back in when I think it should run again. Or... could I just leave it by the side of the pool so it would run straight forward and fall in when the timer function tells it to? I could see that running the pump dry might be bad, although it wouldn't be for very long... unless it uses the water pressure to drive the wheels. Then my brilliant idea is garbage. Is it?
Also, why is there no robot that gets reeled up by its cord when the job is done and dropped back in when it's time to go again? I'm willing to accept royalties for the idea.
