Can you run a pump off a generator?
Dirk
10,338
Central California
Pentair Intellichlor IC-40
Sounds like you faired OK, at least pool-wise. Glad to hear it. Hope you don't have too much of a mess to clean up!
generessler
320
Chapel Hill, North Carolina
Jandy Aquapure 1400
For the record, the cleanliness of small generator power is best for inverter generators. Next is ones with brushes and a voltage regulator. Next is brushes and no voltage regulator. Brushless generators are the worst. They give very dirty power. They're really only good for things like incandescent lights (even LEDs might have a problem) and heaters.
Tegguy
392
Winter Garden FL
Wasn't too bad just some moss and small limbs. Luckily for us we missed the worst of it however, I feel bad for the people that took a worse hit than us.
Looks like mine has brushes with an AVR
Reactions: Newdude and Dirk
Darin
245
Muscatine/IA
The inrush current upon start is what kills the motors. If your motor controller has a slow ramp up and your generator if sized for your full rpm motor then you should be fine.
I have a bit of a different set up than most. I have a VFD where i have my ramp up to 60 hertz at 8 or 9 seconds. It is a lot easier on motors. Hope your beer stayed cold.
