Can I wire GFCI to Aux Relay for landscape transformer
Drewb4
4
Bolton, MA
Hi Guys--
I am wondering if you can tell me if this situation will work.
Landscapers plugged a Dauer low voltage transformer for landscape lights into the GFCI outlet on the Pentair Easytouch. The GFCI is powered by a single non-GFI protected breaker in the load center-- doesn't go through any relays or anything. We do have a second outlet wired in at a secondary location some distance from the panel which is protected via the GFCI outlet at the ET.
My question is can I wire from the Line/Load on the GFCI to an unused Aux relay, and then directly wire the transformer to the relay? Would that still provide GFCI protection to the 2nd outlet and the relay? I just want to control the landscape lights through the ET via a feature circuit
Thx
-D
ajw22
18,890
Northern NJ
Yes, you wire the hot wire from the LOAD side of the GFCI outlet to the Aux relay, and then directly wire the transformer to the relay. You connect the neutral wire from the transformer directly to the LOAD side of the GFCI outlet.
Drewb4
4
Bolton, MA
Perfect, thanks! Makes sense
