Can I see my pH on my automation
Neoex
8
Tulsa
Just getting my pool going (brand new) I bought the IntelliPH, is there a way I can see inside my app what the pH level is to know if I am high/low?
Jimrahbe
15,405
Bedford, TX
N,
As far as I know the IpH just dumps in a set amount of Acid over a set amount of time.. It does not measure the actual pH level..
I suggest that you fill out your pool's signature (settings then signatures) that way we all know what you have and makes answering questions much faster.
Neoex
8
Tulsa
Thanks it looks like you are correct, kind of a bummer, does anyone run IntelliChem just to see chem levels and not actually use it to balance the pool? I have heard alot of mixed reviews on IntelliChem
Jimrahbe
15,405
Bedford, TX
N,
It is just not needed.. If you add acid and test everyday for a week or so, you soon get a feel for how much acid your pool uses each day. Set your iph for that output and then test once a week to see where you are.. Soon you will know just how often you really need to test.
My plan was to buy an acid feeder, so I experimented first with adding a little acid every day to see how well an acid feeder would work. I found that if I added 5 oz. of MA each day my pH stayed between 7.7 and 7.8... It has become a habit now, so I have put off getting the feeder..
