I need to do some testing for a leak. I have a pool that will allow me to shut off all suction except from the main drain. Is it a problem if I drop the water level below the returns. I am thinking that if I do that and run the pump the water will just flow out of the returns and waterfall back into the pool.
I only plan to do this for a few days so that I can test if there is leaking from the returns then I would fill it back up or close the pool for the rest of the winter. Am i wrong, is this a bad idea?
