Can I run my heater while I am at shock level?
Smehltrett
48
0
Olney
#1
So I just finished my opening slam (only took 3 days yay!) and the family is looking forward to using it as soon as FC drops below shock level. However the water is still very cold so I would like to start running the heater ASAP. Will the high FC levels be damaging to my heater? Im at around 35ish cya and 14FC.
Jimrahbe
10,162
1
Bedford, TX
#2
S,
Most heater damage is caused by pH problems and not high FC... the problem that I see is that at an FC of 14 the pH test is not accurate.
I am not a heater guy, but I would let the FC drop below 10 so that you can test your pH before firing up the heater..
Thanks for posting,
