I'm looking at a 1.5 hp Pentair VS pump, and I would like to replace my old pump without buying a new electronic interface. I'm considering a 1.5 hp model#342001
My setup today is:
My pump runs on a timer
My SWG runs on a time withing the running time of the pump. (the SWG timer is set trip on and off only when the pump runs)
MY solar water is controlled by a thermostat that automatically turns the pump on independently.
I'd like to use the VSP the same way. I want to have the manual switch turn it on, have it ramp up for a minute, then cycled down the power saver rpm I set it at.
Is this doable?
My setup today is:
Is this doable?
