Can I leave my Chlorine level high over winter?
8ightiesfan
Active member
May 26, 2020
37
Canberra, Australia
From Australia so now entering the winter period.
I recently shocked our pool to clear a small green algae outbreak and now it is crystal clear and well balanced, except the chlorine level is still very high around 13ppm.
Now that the pool will not be swum in again until September can I just leave the Chlorine level high? Will this cause any damage to the pool or equipment? I am just thinking of leaving the Chlorinator at a normal level and let the Chlorine level drop slowly to help keep the pool sanitary.
Thanks
mknauss
44,406
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Test strips don't cut it but if you believe them, that is up to you.
You should check out Clear Choice Labs. They have proper test kits available in Australia.
8ightiesfan
Active member
May 26, 2020
37
Canberra, Australia
Thanks, I have been looking into a more complex test kit than the 4in1 I use now. I will check them out.
In answer to my question, assuming CYA is ok which I will confirm, will leaving the FC level high cause any long term issues?
mknauss
44,406
Laughlin, NV
Fiberglass
I assume a 'OK' CYA is something around 30-50. If so, it is fine. Nothing will occur.
thefloatqueen
958
Columbus, Ohio
Thanks
I sure did!! I closed my pool at SLAM level (20 ppm since my CYA was 50) as late as I could in the fall and would periodically add a little liquid chlorine a few days a month when the water wasn’t frozen and use a brush to swirl it around (I did not use a winter cover.) You don’t lose as much FC in the colder temperatures, especially if you are covering your pool. But no regrets here. Easiest spring “opening” ever!
8ightiesfan
Active member
May 26, 2020
37
Canberra, Australia
Frozen pool!!!? We don't get that cold here ? Great to know I can maintain a high FC level and adjust it down when it warms up. Thanks
  • Love
Reactions: thefloatqueen
