I moved into a home that comes with a 23,000 gallon inground chlorine pool. We just opened it, and I'm planning to maintain it myself, except for professional opening and closing.
The past owners installed a Frog branded chlorinator system that is somehow hooked up to my filter pump. My pool opener told me how to add more "tab packs," but I've been reading on here that it is easier to use liquid chlorine to avoid CYA issues. So I'm hoping to stick to liquid chlorine, baking soda, and muriatic acid for most of my pool maintenance needs.
To that end, do I need to do anything, other than not refill with another tab pack after this one is done? Do I need to, for example, remove the last tab pack, or bypass this chlorinator entirely, to avoid other problems? Or is it ok for me to just ignore the chlorinator and start balancing with liquid chlorine?
