Hello all, first time posting here.
I have a 15,000 gallon in ground pool with a cartridge filter and pump sitting a bit above water level (roughly under 2 feet). Everything is working fine, but I'd like to re-plumb the whole setup so I can accommodate a heater. To make more room in the same spot I would need to create a higher platform for the filter to sit on. Basically the filter would site at a high where the intake would be about six inches above the pump's outlet. My question is would there be any issues with doing this?
