Calling pump/hydraulics gurus
CrystalRiver
640
Massachusetts
Would a PureLine 1.5 HP, PL1507, be too much pump for my system? I'm looking for a cheap two-speed pump, but everything seems super oversized for my setup.
I have no problem running on low speed 99% of the time, so long as nothing will break if it's flipped to high speed for some reason.
One skimmer, 1.5" flex to current pump (1 HP Hayward Power-Flo LX), to S166T sand filter (100 lbs, 1.4 sq ft), to flex hose to hard pipe to single return. All plumbing is 1.5 inch.
ajw22
25,665
Northern NJ
Pentair Intellichlor IC-60
If your 1 HP pump works fine then the 1.5 HP should not be a problem running at it's low speed.
