I recently relocated from Houston to the Albany, New York area, and opened my new pool yesterday. I have a roman double sided pool with a vinyl liner and the following dimensions - 18X36. The two half circle ends are 4 ft in length, the shallow end is 3 feet and the deep end is 8 ft. I am guessing the pool size in volume is 24,000 gallons. How can I verify the volume of water my irregular-shaped pool holds? Does a vinyl liner impact the pool chemistry? Which chemicals can I add to the pool at the same time? Do I need to manage the phosphate levels in my pool?
Here are my numbers:
FC - .05 ppm
TC - .02ppm
CC - .15
pH - 7.4
Hardness - 142 ppm
Alkalinity - 74 ppm
Cyanuric Acid - 50 ppm
Copper - 0
Iron - 0.1 ppm
Phosphate - 1206 ppb
FC - .05 ppm
TC - .02ppm
CC - .15
pH - 7.4
Hardness - 142 ppm
Alkalinity - 74 ppm
Copper - 0
Iron - 0.1 ppm
