I suspect both of those are a waste of time and can be eliminated? seems like I remember reading such. Does the clarifier not help group particles to catch in filter or no? I'm surely glad to not use them if staying balanced is sufficient.
No, your right of course, we all have different tolerances. Read your thread in one go and i felt awful for your problems, they frankly scared me.Hi seribus, you might want to call Tallman pools. Ask to talk to Rebecca. She was under the impression that only one other person had an issue with ecoFinish and that was someone that only had it in one spot where their floating chlorine dispenser was sitting in one spot in the pool. I didn't think that was you. This is what I'm concerned about. What happens if we pay to have this fixed and it just keeps happening? They better fix it again.
@Kellyp - they all have their issues. We wanted a salt water pool and didn't want to have to wear water shoes in the pool so we didn't scrape our toes.
I probably misspoke. It sounds like you will do fine with it.I'm not sure why you are saying non-chlorine shock is a mistake. Please clarify.
@seribus, can you share your current CYA as well please?FC 3
Ph 7.6
Ch 230
Ta 90
Salt 4000
Temp 88
CSI -0.25
LSI -0.25
Not confused. There are 5 types of chlorine. Bleach is sodium hypochlorite. I was told I can't use that in my ecoFINISH pool. A second type of chlorine is Calcium hypochlorite. Seribus was using that and was told it caused the issues with his ecoFINISH finish so we can't use that. A third type of chlorine is dichloro-s-triazinetrione which is what I was using with the Clorox xtra blue shock plus it has other ingredients. Stopped using that last year when I talked my husband into not using it. It took awhile, but I finally convinced him we didn't need to proactively shock the pool. I believe that I can use pure dichloro-s-triazinetrione tablets during the winter when my SWG won't work, but I'm going to have to clarify with ecoFINISH on that. Now I'm finding that I need very little "extra" chlorine in the pool because my SWG takes care of it. But, when we have parties, we need a little more of a boost. Because of this ecoFINISH finish, I have been told I have to use non-chlorine shock or potassium monopersulfate for those times. I'm not sure why you are saying non-chlorine shock is a mistake. Please clarify.
