Calcium issues
Envieddesigns
20
New Jersey
Good evening all,
Most of my precast cement copings need to be reset and re-grouted as there are several open joints, on this particular spot there seems to be some calcium build up & water leaching through. As well as the tiles show signs of calcium deposits. The area is not hollow though I’m assuming it’s due to the opened coping and the area of the cement deck above has a crack near the skimmer as well there is one other area that is worst with hollow sounding tile an a small portion of plaster beneath though I can only attach one photo here.B7598C91-1577-4CB5-84B8-4B15F85339E1.jpeg
Texas Splash
30,375
Fiberglass
CircuPool RJ-45 Plus
Good morning and welcome! :wave: You certainly could have some calcium scale if your chemistry levels allowed the "CSI" to remain elevated for an extended period of time. Sometimes we see what appears to be seeping and streaks running out and down from grout lines which in some cases may be efflorescence - moisture from behind. For now, you can try applying a 4/1 mixture of water/muriatic acid and brushing the area. If you need to get more aggressive, a pumice stone may help, but be careful not to scratch the tile. Do test areas first. The links below may give yo more info.
Envieddesigns
20
New Jersey
Thanks TS, you know what I notice though is during the season the areas don’t have a real issue with it at times I do find like a tiny dot of calcium if it’s calcium under the water on the walls or a small line that forms brushes away easily. But the off season during the winter when the portion of exposed plaster that isn’t under water really calcifies over the months. I always bring my water level below the returns at the end of the season I don’t put my cover on since we don’t have any trees. And by the time the season is about to begin from rain and snow the level is about below bottom of the tile. Is it bad to leave that water that low?
Texas Splash
30,375
Fiberglass
I don't think the water level at closing has anything to do with it. Quite the opposite really as I'm surprised that you would see calcium deposits form on those areas when not underwater. Maybe that goes back to the efflorescence? If you feel the need to confirm it's calcium, try to obtain some pieces and pour some acid on it. If they fizzle it confirms calcium. Let's bring a local into the conversation - @ajw22 thoughts?
Reactions: Envieddesigns
ajw22
25,663
Northern NJ
Pentair Intellichlor IC-60
Hard to say if it is efflorescence or water line scale or a combination of some of both. I see those things along my tile. I write it off to what happens to things sitting outdoors in the elements and haven't tried to figure out all the chemistry.
We have snow and we have various pollution in the air falling on the snow that then gets into the snow melt that runs back into the coping and tile. Just seeing the difference in the colro fo my deck and coping where it is covered for the winter versus uncovered for the winter tells me there is a lot of pollution that comes from the air during the winter.
