Calcium Hardness
Gofrogs727
Active member
Jun 11, 2021
42
Aledo, Texas
Calcium hardness tests out at 250ppm (using Taylor 2006K). All other ranges are good.
Pool is located in North Texas where we get a ton of sun. TFB "ideal" CH ranges is 350-550ppm for a plaster pool. But I have also seen in some of the comments that if your pool gets a lot of sun that CH will rise naturally on its own. Is that the case? Or should some to raise it to 350ppm?
mknauss
44,426
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Please post a full set of test results.
If your fill water has calcium in it and you use fill water due to evaporation, your CH level in your pool water will rise over time. If you have a lot of rain and over flow from the pool due to it, your CH level in your pool water may fall.
mknauss
44,426
Laughlin, NV
Fiberglass
Your CSI is on the low side I suspect. Are you tracking that?
How are you chlorinating?
mknauss
44,426
Laughlin, NV
Fiberglass
ok -- you do not want that to go any lower.
You could switch to using cal hypo to chlorinate for awhile if you wish. Or add some calcium to get to 300+.
