Calcium Hardness
skyfly27
19
Springfield Missouri
Can someone tell me why calcium hardness is important for a gunite pool? I measured mine at 150. The pool math calculator says I need to add 25 lbs of calcium chloride. Just wondering why this is necessary?
Texas Splash
31,434
Fiberglass
CircuPool RJ-45 Plus
When the CH level gets too low in a a plaster pool, the water is starved for calcium and looks for a place to grab it - the pool shell. Over time that can result in plaster etching and damage. For that reason, it's important to have the minimum amount required. By contrast, if you had too much calcium and it over-saturates the water, it looks for a place to stick - scale.
skyfly27
19
Thank you! Is there a more specific range? I am seeing 350-550
Texas Splash
31,434
Fiberglass
350-550 is about it, The range for CH gives owners plenty of flexibility to keep the plaster safe while preventing scale. Keep in mind a lot has to do the 3 other factors: water temp, TA, and pH ... pH having the biggest influence. But if you keep all your numbers within those recommended ranges, you'll be fine. Plus, the PoolMath APP will let you know if any area should be addressed, so if you have a questions if that happens just let us know.
Reactions: skyfly27
