- Apr 10, 2018
- 3,717
- Plaster
- CircuPool RJ-45
I'm seeing calcium flakes coming from the returns, most likely being generated in the SWG cell. I collected some flakes this morning with the net and they tested positive for calcium (MA drops test). The flakes are soft and dissolve on contact.
Test results:
FC: 8
CC: 0
pH: 7.6 (Ranges from 7.2 to 7.6)
TA: 80
CH: 525
CYA: 80
CSI: -0.06 (Ranges from -0.33 to -0.06)
Temp: 82-87 degrees
Fill water TA is 130. To battle rising TA, I aerate daily using the spa spillover and add MA every other day to knock pH back down to 7.3 ppm from the 7.6 to 7.7 range. CSI rarely, if ever, gets into the positive range.
Curious what in my chemistry is causing the calcium flakes.
I suppose I'm a good candidate for borates?
Test results:
FC: 8
CC: 0
TA: 80
CH: 525
CYA: 80
Temp: 82-87 degrees
