Cage cleaning advice needed
Gena with an E
3
Gulf Shores, AL
Hello,
Anyone have any advice on cleaning a pool cage?
I've only used water to clean it and that seems to work well.... I'm afraid of using any chemicals on it because I don't want to damage it or have weird chemicals ending up in the pool water.
Should I SLAM the pool prior to cleaning the cage to try to avoid the water getting gross from the "drip down"?
Thank you!
Gena with an E
3
Gulf Shores, AL
Nice..... I do have a power washer but not one like that.
What I have done is wet the beams down and then with a giant extension pole with a lambswool type window washer "wipe" everything down.
Then I rinse it all... and it all goes in the pool.
The last time I did this it took almost 2 weeks to get the pool water back to being crystal clear.
So I wonder if there is something I can do to the pool (SLAM maybe) to help counter whats going into it.
