Bypass Polaris
evanwellens
143
Stony Point, NY
I need to get my pump to a rebuild shop. In the meantime I'm looking for a way to plug the polaris pump hose that connects to a T at the filter outlet. Anyone know what I can use ? Otherwise the pool would drain when run , and the shop might take over a week to repair so I'd rather not let the pool go cold and greed. Anyone have experience doing this ? Thanks
HermanTX
2,412
Katy TX
Maybe better if you can post a picture. However, can you tie the inlet hose (going to the pump) to the outlet hose (going back to the pool). Then the water will just circulate as if the pump was there.
jeffchap
1,819
Edmond OK
Why not just take the hose off at the Polaris end and leave it dangling in the pool? You might need to weigh it down by tying a brick or something to it to keep it from wriggling out. But the repair shop shouldn't need the hose.
duckcmmndr
338
Arkansas
Hayward Aqua Rite (T-15)
Need a picture of the pump and it's connections to help you here.
Is is plumbed with the flex piping and fittings that comes with the pump? Like in this picture:
If the answer is yes...those fittings on the end of the flexible piping are 3/4" fittings and you would simply use a 3/4" PVC plug to block off the supply to the pump. It will look like this:
Once again...snap a picture of your booster pump and how it's connected to your pump plumbing and we can better help.
evanwellens
143
Stony Point, NY
That would be great but not sure what I can
The distance is too far But good idea
evanwellens
143
Stony Point, NY
Awesome this is what I was looking for. Seemed like a custom hose , but if it's just 3/4 that's should be easy. You wouldn't happen to know if that is O/D or I/D ?
Rocket J Squirrel
1,188
Alamo, CA
It looks like you should be able to move the flex hose from the pump output to the tee after removing the hose that's currently connected to the tee.
HermanTX
2,412
Katy TX
Sorry here is a picture
Take the connection out of the PVC that leads to the intake of the pump. Screw the connection from the out put side. Those connection threads should be the same. So you have 1 hose from the PVC to the outgoing PVC.
EDIT - I see @Rocket J Squirrel had same idea but provided a picture - thanks.
HermanTX
2,412
Katy TX
Hope it reaches.. Now I wish I cut them longer ;-)
It appears it will reach but if not - connect the 2 hose ends together with a coupling - it should be just standard NPT threads so you can buy a coupling to screw the 2 adapters to form 1 line.
evanwellens
143
Stony Point, NY
It reached and so far so good. Had a harder time getting the rusty wires cleanly disconnected. I'm kind of surprised the pump has so much rust , it's not that old.
Anyway thanks so much for the help !!! Hopefully the Pump shop can fix the motor and we'll have our little robot back in busisness.
Reactions: HermanTX
