Bypass heat pump
ethany
527
Trenton NJ
I bought two multi port valves to bypass the heat pump but can't figure out how to make the handle open and close 90 degrees and not 180 degrees.
I'd like to post pictures but it been awhile since I been on this site and can't seem to find the icon to click on to post a pic
Thanks
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
More here on pics, Posting Photo's Tutorial
Do you have actuators? If so, you have to open the motor and adjust the cams. If just the valves there should be pins in the handle that can be removed and placed in different holes to hit the stops.
