Burning through Chlorine
Msfish
Active member
Oct 29, 2018
41
Richmond,TX
Can you give me some thoughts on why my pool would be burning through chlorine?
My chemistry as of this am..
Ch 5.5
TA 80
pH 7.5
CYA 50
CC 0
I am using 10% bleach. Each morning I am having to add at least a quart to get the CH to around 7. It tends to drop to around 4-5 throughout the day.
It is warm where we live and my pool temp is 76’ at 8:30, so that may be the culprit. Or could it be the efficacy of the bleach. The date is only about 2 mths old. My pool passes all SLAM criteria.
YippeeSkippy
13,466
Evans, Georgia
I suspect your pool gets a mess of sunlight, right? Without algae chewing through chlorine sunlight would be a big reason.
Have you ever considered putting in a SWG so you don't have to be the one hauling jugs of chlorine home?
Maddie :flower:
Msfish
Active member
Oct 29, 2018
41
Richmond,TX
Good to know this is normal! This is my first summer to start using bleach. I ran into issues with the tabs at the end of season last year and switched over.
Yes, my pool gets full sun almost all day.
I would like a SWG, but when I mentioned it to hubby, he was not interested because of the expense. He has nothing to do with the pool except enjoy it.
Bvacchiano
244
Sugar Land, Texas
Howdy neighbor! Yeah looks normal to me. I lose about 2 ppm a day right now. If you are getting full sun it may be closer to 3/4. Yeah I’d be stashing money away and getting that SWG. I’d rather saw my arm off than not have an SWG here in Sugar Land.
nabril15
444
Miami, FL
MsFish - I go through 1 or 2ppm daily here in Miami, and sometimes a bit more. I've come to learn that chlorine is consumed hourly by the sun or algae; it's a fact that must be accepted. If the algae is under control, then the bright star up in the sky is to blame. Don't forget tonight's super moon, btw...
compren
7
Spring, TX
The Woodlands here...I am going through 5 cups a day of 10% and I'm probably gonna have to up it some because it's gone by the afternoon (I am adding the night before and testing in the morning). I get full sun all day as well.
