I removed some loose bullnose brick coping (8 x 3 5/8 x 2 1/4) to reset and replace cracked white joint material. I tried to get pool remodelers/pool repair people to do this work, but they all were too busy, so I'm doing it. I'm looking for advice on the appropriate material to use in the coping joints.
The 20 year old pool has curved corners, and the pool builder used wedge shaped joints rather than cutting bricks. So joints at corners vary in width from 3/8 at the narrow end to 1 1/4 at the wide end. The joint filler is white with beige coarse sand and is the full depth of the joints. . I can't seem to find a post or some advice for the appropriate joint material to use for this size joint. One builder said they use tile grout, but the joint dimensions far exceed the maximum width and depth for tile grout. Some comments on this forum suggest Type S mortar but these joints seem too wide for that as well. Any suggestions would be greatly appreciated.
Thanks
Thanks
